Artikel-ID : 00305034 / Laatst gewijzigd : 20/01/2026Afdrukken
    Can I shoot using NightShot?
    You can if the AUTO/MANUAL switch is set to AUTO.
    Also, remove the supplied lens hood.
    Select (CAMERA SET) ' [NIGHTSHOT] ' [ON].
    To cancel, set [NIGHTSHOT] to [OFF].
    Hint: To easily switch on and off, you can assign the function NIGHTSHOT to one of the Assign Buttons "Assign 1" to "Assign 6"
